transittaxilad wrote:This engine looks like it's a internal water pump on timing belt, one think now I still don't very much understand (it now not leaking) that coolent does circulate, but not via rad, or any of the two pipes that run to expansion tank, but all others get hot.
I will mention about pump, but to me I sure pump working as it should, as theirs no powersteering loss if it is that type. It's a 2l tdci or is tcdi, with last two letters being red, if that helps to what pump it is.
transittaxilad wrote:Well okay, like I said at start of post, I'm no fix it and have no knowledge of fixing bus, vans or cars, I only check levels and pressures and drive, that's it. I came on hear for advise not sarcasm.
ive said water pump 3 times, the sarcasm got your attention didn't ittransittaxilad wrote:Well okay, like I said at start of post, I'm no fix it and have no knowledge of fixing bus, vans or cars, I only check levels and pressures and drive, that's it. I came on hear for advise not sarcasm.
