Dash removal
Dash removal
Postby Airthies » Sat May 30, 2015 3:07 pm
Hi guys
Before I go wrecking everything. Is there an easy way to take the dash out to get to the harnesses?
Obviously the plastics riveted to the frame but is it easier to drill rivets or take out steel frame complete to get to the wiring harness?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Dash removal
Postby loot » Sat May 30, 2015 3:17 pm
Remove all outer plastics(Phillips) then unscrew the whole dash, i didn't remove the dash fully to get my loom out, the main loom runs below the screen, i would advise you to unclip the gear cables from the lever tho as it'll put stain on them, i was able to mostly remove my dash enough to pull it about 4 inches away.
Ids map here
loot
Re: Dash removal
Postby Punto443 » Sat May 30, 2015 4:13 pm
give a shout if you need a hand, I'm pretty free tomorrow and have had the dash out a good few vans :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
