Mk7 OBD scanner and warning light
Postby Thetransitguy » Mon Jun 01, 2015 10:16 pm
Hi guys this is my first post and before I go on I would like to thank every single person on this forum for they contributation to make it what it is today now on with the problems ...
I have a 56 plate mk7 100 t350 and first problem is driving home today was all fine then I had a loss of power for a second or 2 then the power train light came on (cog with ! Inside) oh and it's a diesel and it has stayed on permanently but otherwise van is perfectly fine and I'm also looking to buy a obd scanner to help diagnose these problems myself and I'm on a very tight budget :( I have been looking of eBay and I have found a f-super 2 for £20 and says it reads ford transits just doesn't say what models will this work on my mk7
Thank you very much for your contributation to my problems :D
Thetransitguy
Re: Mk7 OBD scanner and warning light
Postby bazw » Tue Jun 02, 2015 1:11 am
they will work on the full range, it will let you do most of the diagnostics ok
does the van have 2 batteries under the drivers seat? if so get the front one looked at as they appear to cause a fair few electrical faults
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Thetransitguy » Tue Jun 02, 2015 3:08 pm
Great that you I will be getting one of those the :D and yes it does and the auxiliary battery did go flat last week could this be a factor?? Thanks for your help :)
Thetransitguy
Postby bazw » Tue Jun 02, 2015 4:45 pm
the Aux battery runs all the electrics so can be a huge factor
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Thetransitguy » Tue Jun 02, 2015 5:19 pm
Ok but it's been driven a lot since then so the battery should be pretty full shouldn't it? Never had a problem with the battery's before apart from then when the doors were left open all day which was my fault
Thetransitguy
Postby loot » Tue Jun 02, 2015 5:21 pm
Front batteries die on mk7s but because the starter battery gets linked, you have no problem starting so you can be unaware :-(
You should get them drop tested just to rule that out.
Mk7 tend to be a bit hungry on the front battery too :-(
Ids map here
loot
Postby Thetransitguy » Tue Jun 02, 2015 5:39 pm
Ok I will do that thank you ! I noticed when the aux battery died the radio didn't work and when I opened the door the instrument cluster lit up and the dials dipped and made a funny noise I'm guessing because the was very little power left
Thetransitguy
