engine tappy
engine tappy
Postby sharpy » Mon Jun 01, 2015 10:32 pm
Ive got a mk7 10 plate transit 110. When I first start in morning it sounds very tappy coming from engine, is this common? Ps I've had it for 3 weeks now, my last transit was never like that. They serviced it before I bought it, would this may be cheap oil?
sharpy
Re: engine tappy
Postby knobby1 » Tue Jun 02, 2015 3:22 am
sharpy wrote:Ive got a mk7 10 plate transit 110. When I first start in morning it sounds very tappy coming from engine, is this common? Ps I've had it for 3 weeks now, my last transit was never like that. They serviced it before I bought it, would this may be cheap oil?
Timing chain rattle maybe, tensioner issue....!? Try some fresh 5/30 syth or semi-synth oil and a new filter and see if it helps...unlikely if the tensioner is gone though..!
Re: engine tappy
Postby woolieoldgit » Thu Jul 02, 2015 11:04 pm
WHAT KIND OF TAPPY IS IT ? big end , piston, tappets, injector knock .... mine has a knock that sounds a bit like a big end just starting to go but this dissapears when the temp goes over 1/4 way up like its connected to the cold start system in the ecu. ANYONE HAVE ANY IDEA WHAT THIS MAY BE ? i was thinking one of the sensors but which one ?
woolieoldgit
Re: engine tappy
Postby karl » Fri Jul 03, 2015 5:51 pm
tappets are hydraulic none adjustable
you can get knocking, tapping threw not having the prv and scv changed updates etc done
but i hear these nearly everyday :D now if it is something to worry about or just leave
best thing to do is post a you tube video of the noise
karl
Tranny Lover!!!
Re: engine tappy
Postby bigjohnthomas » Fri Jul 03, 2015 7:01 pm
Does it still do it when you press the clutch in ?
Regards
Nurse allcock
bigjohnthomas
Re: engine tappy
Postby ake » Sat Jul 04, 2015 10:17 am
You didn't get a 110ps in 2010 :? :? :?
