2009 all wheel drive 2.4 140 ps engine blown up!!!!!!!
Postby jjoiner1 » Mon Jun 08, 2015 9:21 pm
Just what you need on a monday morning!!! Big cloud of smoke loss of power then cut out leaving oil everywhere!!
82,000miles full service history!! Im proper ill with this van!!!
Had it recovered and looked at and its popped no 1 piston, so no compression and presurizing the sump hence the oil!!
New engine required!!!!!
Only saving grace it broke down next to a lay by with a butty van and a decent view so i could cry into a brew!!!
Any advise appreciated
jjoiner1
Re: 2009 all wheel drive 2.4 140 ps engine blown up!!!!!!!
Postby loot » Mon Jun 08, 2015 9:42 pm
Oh dear :-( not sure what advise to give tbh, apart from buying a new engine of course :wink:
Boss got a full motor new from QUICKO for 2300, only had to put his pump and injectors on it plus manifolds etc .
Ids map here
loot
Postby jjoiner1 » Mon Jun 08, 2015 10:14 pm
any ideas on the engine type/code im looking for or are the short engines the same?
jjoiner1
Postby bambi mk 1 » Mon Jun 08, 2015 10:25 pm
The code is on the ns b pillar.If your going down the short engine route check your own before you commit yourself as you may get away with a new piston or pistons. Make sure you get your injectors tested :)
bambi mk 1
Postby jjoiner1 » Sun Jun 14, 2015 9:12 am
bambi mk 1 wrote:The code is on the ns b pillar.If your going down the short engine route check your own before you commit yourself as you may get away with a new piston or pistons. Make sure you get your injectors tested :)
Thanks for the reply...Why check injectors?
jjoiner1
Postby motorman116 » Sun Jun 14, 2015 9:15 am
a faulty injector can cause problems with the pistons, (melted piston)
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby karl » Sun Jun 14, 2015 1:18 pm
All of the above
karl
Tranny Lover!!!
Postby jjoiner1 » Sun Jun 14, 2015 8:12 pm
How do you attach pictures ? Ihave done it before but ive got brain fade!!LOL
jjoiner1
Postby loot » Sun Jun 14, 2015 8:18 pm
Reply to thread then look down and you'll see attachments, click on it and crack on :-)
Ids map here
loot
Postby jjoiner1 » Sun Jun 14, 2015 9:07 pm
jjoiner1
Postby jjoiner1 » Sun Jun 14, 2015 9:08 pm
jjoiner1
Postby jjoiner1 » Sun Jun 14, 2015 9:09 pm
Gutted!!!!!!!!
jjoiner1
Postby motovanner » Mon Jun 15, 2015 1:26 pm
Did you have the van "tuned" in any way shape or form?
Facebook/All tents Camping Group
motovanner
Postby jjoiner1 » Mon Jun 15, 2015 7:50 pm
Yes, Martyn @ vantuner did it for me ... focus was on economy rather than power ,but there was some obvious changes, also did egr delete...
Im wondering if I should of have him re map again after new injectors were fitted in case this had some sort of effect on whats happened, vans probably done about 10,000miles since re map , injectors were done about 2,000 miles after re map...
jjoiner1
Postby karl » Mon Jun 15, 2015 8:02 pm
oEdited
Was it a 140 standered
karl
Tranny Lover!!!
cron
