sliding door lock
sliding door lock
Postby stevetiler » Mon Jun 15, 2015 6:15 pm
Hi all,
Got a wierd problem on a 57 plate transit,the sliding door will not unlock with the fob unless I pull on the outside handle first!
It makes all the right noises but unless I give the handle a pull first It wont unlock! I took off the hardboard door liner and cant see anything obvious,same thing-if I pull on the cable first it unlocks! Any ideas?
Thanks Steve
stevetiler
Re: sliding door lock
Postby transity2000 » Tue Jun 16, 2015 12:22 am
Got the same problem but mines I have to push the edge of the sliding door then it will open up ain't had time to open up and have a proper look but will look soon
All i wanted was a trouble free transit
transity2000
Postby stevetiler » Tue Jun 16, 2015 7:22 am
I know the guy I bought the van from and he said it started when he had the door rollers changed!
stevetiler
Postby transity2000 » Tue Jun 16, 2015 12:09 pm
Mines were fine till couple month ago I recokon it was my generator wen it hit the door from the inside due to my driving lol.but wen I tired to open it today I pushed the door close even more first then unlocked it then it opened straight away so I'm guessing it's not touching the connectors Probaly so it could be something needs adjusting if either the door or contacts
transity2000
Postby B19 DAN » Tue Jun 16, 2015 12:40 pm
I have a mk6, and my sliding door only opens when the van has been 1st unlocked, say on a morning, but if i were to lock my van again then unlock it the door stays locked, its had me baffled for ages, also it sounds like everythings working, but obviously somethings not right.
B19 DAN
Postby stevetiler » Fri Jun 19, 2015 3:40 pm
anyone?? This is driving me nuts!!
stevetiler
Postby stevo » Fri Jun 19, 2015 3:45 pm
Its the alignment of the door, i had thd same on an old mk6 works van
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby stevetiler » Fri Jun 19, 2015 3:53 pm
It looks perfect- only thing I can see is the 3 pin connector plate has low markings ie looks like the plate could do with moving up a bit but looks like it's riveted solid!
stevetiler
Postby stevo » Fri Jun 19, 2015 4:31 pm
Try cleaning those contact with wd40. When I had problems with mine I just re aligned the door and it was perfect
Formely ibanez2005
stevo
Postby motorman116 » Fri Jun 19, 2015 6:29 pm
I had this problem and it ended up being the lock unit itself failing.....
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
