transity2000 wrote:got a set of drl need ignition live to get power.can I take power straight from the engine fuse box r3 with the live wire having a fuse . Or can I connect to the jumpstart point will that be ignition live or permanent live thanks guys
transity2000 wrote: relay and diode bit
limitedblack wrote:Mike wrote:
That's my one in this picture, just use this to power a relay only, using the power from the side of this fuse box. It is rumoured that powering something direct from this point can cause malfunctions elsewhere. So I have a relay with the customary diode across it to stop it spiking back when de-energised.
