Sloppy gears and won't go in reverse
Postby forzamc » Fri Jun 19, 2015 10:02 am
Hi
My mk6 transit has recently developed a problem
It won't go in reverse unless I turn the engine off, and going into other gears feels really sloppy.
Any ideas?
Thanks in advance
forzamc
Re: Sloppy gears and won't go in reverse
Postby B19 DAN » Fri Jun 19, 2015 11:28 am
I had the same problem with mine, but also used to jump out of reverse, sometimes grinding when trying to select 2nd gear aswell, changed the gear cables, and it was like driving a brand new van.
B19 DAN
Postby bigjohnthomas » Fri Jun 19, 2015 11:50 am
Is it fwd or rwd ? What are you wearing?
bigjohnthomas
Postby forzamc » Fri Jun 19, 2015 12:33 pm
It's a 52 plate t100, think it's front wheel drive.
forzamc
Postby Punto443 » Fri Jun 19, 2015 4:06 pm
Gear cables or gear selector turret worn, I'd say
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby forzamc » Fri Jun 19, 2015 6:15 pm
Thanks a lot guys will try replacing cables, the only I don't understand is why it would go in reverse without the engine running, does that not sound like a clutch fault?
Before the gears went sloppy there was no indication of any fault with the clutch?
forzamc
