Lack of power when cold
Postby sharpy » Sat Jun 27, 2015 9:49 am
I have a 10 plate 115 and when cold on idle it fluctuates up and down on the revs, when driving first thing it has a lack of power as if it wants to cut out. And it sounds like a tractor. When it warms up its ok.
Is this lack of fuel?
Low on fuel pressure?
Or fuel pump?
sharpy
Re: Lack of power when cold
Postby spooky » Sun Jun 28, 2015 2:31 pm
Try cleaning the MAF sensor, they degrade in performance anyway after 50k, use some electrical contact cleaner that doesn't leave a residue.
http://www.airmassmeterspecialists.co.u ... ID=1081845
http://www.carsdirect.com/car-repair/ho ... low-sensor
spooky
Postby knobby1 » Sun Jun 28, 2015 11:06 pm
sharpy wrote:I have a 10 plate 115 and when cold on idle it fluctuates up and down on the revs, when driving first thing it has a lack of power as if it wants to cut out. And it sounds like a tractor. When it warms up its ok.
Or fuel pump?
How many miles has the machine done? Fluctuating or hunting idle is often a SCV and/or PRV issue. There quite a bit written on them through these forums and quite a common occurrence. Usually replacement of these two valves and a PCM update, pump & injector learns helps.
Postby sharpy » Mon Jun 29, 2015 7:11 am
79000
sharpy
