loot wrote:Do you mean esp?
Does it only come on after driving or would it come on if you started the van for a while?
Typically if it needs to be moving for a while then it is a soft fault generated by things like tyre sizes, wheel alignment, dirty reluctor ring, steering angle sensor calibration, possibly a flattish tyre.
Possibly other things like wiring etc.
And is it the car with squiggly lines coming on the speedo in amber warning light yes?
(Most likely the front wheel alignment i think)
Sorry hit the wrong letter . Yes you are correct it is the esp
The light comes on after driving for a while.
Elimination process so far = Tyres all good, wheel alignment good, pressures good, yes it is the squiggly lined amber car light in speedo.
If I am driving and it comes on I just switch the ignition off with clutch in then back on and bump it, then it goes out again for anything from 10 mins to 20 mins.
Is there anything I can clean myself to try eradicating this and if so where are they located.
Would rather try this than put straight to garage also is it safe to run with light on.
Thanks in advance again. James.
