Power Steering pipe replacement help
Postby Noster » Tue Jun 30, 2015 8:25 am
Hi Guys,
Started replacing my power steering pipe as the old one fail on the MOT due to corrosion. I have disconnected both ends, slacken the pipe clamps so the pipe is free to be pulled but it seems impossible to get it out due to all the bends on the pipe ?
Do I have to remove the support as per attached photo or anything else to clear the way for easy extraction or is it just a case of patiently navigating the pipe out, also whats the best way to remove it from the top via the bonnet or the bottom ?
Many thanks
Mark
Noster
Re: Power Steering pipe replacement help
Postby knobby1 » Tue Jun 30, 2015 9:36 am
Noster wrote:Hi Guys,
Many thanks
Mark
It'd probably help if we knew what transit you were trying to remove the pipe from...Mk6...Mk7..FWD...RWD, petrol/LPG, diesel, engine size etc... There's about a gazzilion combinations of 'em.. :wink:
Postby Noster » Tue Jun 30, 2015 1:32 pm
sorry its a .....
2001 Transit 350 LWB (Mk6)
Engine : 2.4 Diesel
Many thanks
Mark
Noster
Postby v8dave » Tue Jun 30, 2015 1:35 pm
Take the top of the air filter and the hose to the turbo out, then it will be easier.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
