EGR VALE
EGR VALE
Postby paulk2702 » Tue Jun 30, 2015 11:33 pm
Got a blanking plate for my egr valve on my mk6 2.4 duratec engine
unbolted the 2 nuts which hold a pipe support to the rear of the egr valve,
but noticed the bolts that hold the rear pipe to the egr vavle have some sort of splined/star head on them, any ideas on the tool I require to remove the bolts
paulk2702
Re: EGR VALE
Postby knobby1 » Wed Jul 01, 2015 12:03 am
paulk2702 wrote:Got a blanking plate for my egr valve on my mk6 2.4 duratec engine
They're a "Torx" bit...#T30 IIRC...but don't quote me on that... :? Probably best to buy yourself a set of Torx bits....you'll need 'em for a lot of other gubbins on the Transit.
Re: EGR VALE
Postby Brains_transit » Wed Jul 01, 2015 1:54 am
An 8mm socket will fit or around about that size and may need a light tap but will work
Brains_transit
