Help Needed
Help Needed
Postby ginja1000 » Fri Jul 03, 2015 4:46 pm
I have a 2002 transit 2.0 tddi i think.....anyway it runs and drives perfectly for about ten miles then starts to lose power till it eventually grinds to a halt...It will then restart but can barely pull it`s own weight and if you rev the crap out of it it smokes white smoke....Let it cool down and it will run fine again for a while then the problems start again has only started to do this for the last week any ideas anybody ??????
ginja1000
Re: Help Needed
Postby loot » Fri Jul 03, 2015 5:18 pm
Have you checked you fluids and oil? Has it been serviced lately?
Ids map here
loot
Re: Help Needed
Postby ginja1000 » Fri Jul 03, 2015 5:31 pm
was occasionally a bit sluggish so i have changed the diesel filter all fluids are good ....runs as sweet as a drum ...for a while then all hell breaks loose
ginja1000
