matthew*t260* wrote:Cheers for the input aph, do you know if the pump itself would still work if the solenoid is rewired, I've been chatting to someone local and they say they can wire it up, obviously this would work out cheaper than replacement pump and edc and labour cost,
matthew*t260* wrote:I will have the wiring checked throughly first though, whats the best way to check visually or with a meter and trace wires back and check continuity
matthew*t260* wrote:It's been scanned with the big new snap on and has spat out codes
P0000 no code present
B2242 rear cargo door circuit open
B1330 right front door ajar circuit short to ground
Any ideas guys should I assume it's the key and find another locksmith?
matthew*t260* wrote:Thank you very much appreciate that, Il check the wiring tomorrow following your guide and update thread with my findings , I'm hoping I've got a broken wire somewhere but it's probably wishful thinking, she's on 170000 was otherwise running perfect
