Recently picked up a 02 plate 125 350 2.4 LWB and having driven it for a few days I'd just want to check a few issues I have with it - previous van was a TD conversion SWB Mk5.
Gearbox a bit vague - 5 speed - lever seems to centre over 5th/4th if that doesn't sound daft, 3rd hard to find unless very careful, 'dog leg' to find 4th (or reverse, depending on how it feels ....) reverse hard to find when actually wanted - is there a gate I haven't figured out?
No 2.5DI type guts in it - I appreciate it's a big old girl with a tall diff, but it's a bit lacking in the throttle response and bottom end grunt departments. Normal? I remember a work Mk7 135 being the same. I'm assuming it's the TDDI motor as no electrics to injectors, can it be mapped/remapped?
Keeps revving for a second or so occaisionally when you lift off and/or changing gear.
Has it got glow plugs? There's a light comes up on the dash, but only as long as the other 'check' lights do.
Occaisional not starting - fires a couple of cylinders and then dies, and/or a bit of a misfire before it settles, there was air in the fuel filter check gauge thingy but seems to have gone.
Have to say, for a big van it handles and rides very nicely.
Jim
