'lecky window annoyance.
Postby Jim Archer » Wed Jul 15, 2015 11:26 am
Is there any way to disable the drivers window winding itself all the way down if you even look at the button? I find meself inordinately annoyed by this :oops:
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: 'lecky window annoyance.
Postby bigjohnthomas » Wed Jul 15, 2015 11:58 am
Me too :x
But You just gotta keep your poddgy paw pressed on it
bigjohnthomas
Postby loot » Wed Jul 15, 2015 12:28 pm
You'd have to play with the 1 touch relay.
If you tap the button it goes all the way down, if you hold it a second and a half or so, it won't go down.
Think these are bad, try the Peugeot ones :?
Ids map here
loot
Postby Timbo » Wed Jul 15, 2015 3:17 pm
One touch down (on driver's window only).
Tap the "down" button once and the window starts going down. Tap again and the window stops.
"Tap - Tap" drops the window a couple of inches.
Simples.
Timbo
Postby nick:l » Wed Jul 15, 2015 3:30 pm
On a window side note, can you IDS it so that they close automatically on key fob door lock?
nick:l
Postby Timbo » Wed Jul 15, 2015 3:37 pm
I don't think so as it is just a relay in the door and nothing to do with the BCM.
Timbo
Postby Jim Archer » Wed Jul 15, 2015 4:12 pm
Timbo wrote:One touch down (on driver's window only).
Simples.
I should remind you that you don't have this sort of trouble with manual winders :D
I've now discovered another small issue, hold both botton down and the winder motors are obviously short on current. Normal? Or dodgy earth?
Also is there no stop switch at top or bottom of travel?
All this new technology to play with ... :P
Jim
Jim Archer
Postby Timbo » Wed Jul 15, 2015 4:24 pm
The windows can be a bit sluggish at the best of times, especially if the engine is not running.
I only operate one window at a time.
Some talcum powder in the guides helps a little (until it rains).
If you hold the switch down when the window is at the limit of its travel you will overheat the motor and it will trip out and need to cool down to reset itself.
The OTD relay senses the increased current of the stalled motor at the end of travel and switches off.
Timbo
Postby ake » Thu Jul 16, 2015 7:16 am
nick:l wrote:On a window side note, can you IDS it so that they close automatically on key fob door lock?
No. Windows are not bcm controlled
Postby blue estate » Thu Jul 16, 2015 4:31 pm
Also you need both windows to be 1 touch :wink:
blue estate
Postby mobilevanman » Thu Jul 16, 2015 5:31 pm
And why 1 touch down when it rains I want 1 touch up Ford's you got it backwards
why not if u dont someone will
mobilevanman
Postby blue estate » Thu Jul 16, 2015 5:32 pm
mobilevanman wrote:And why 1 touch down when it rains I want 1 touch up Ford's you got it backwards
My 07 Focus Ghia has 1 touch up and down :mrgreen:
blue estate
