mk6 transit rebuilt
mk6 transit rebuilt
Postby garry_noble » Fri Jul 17, 2015 7:08 pm
i know this must be getting boring now but i have just finished engine rebuild for my 135 mk6 ..........i have started it up and all sounds ok , but oil light is on the dash . and it stayed on. im wondering if maybe sensor is stuck as its been in pieces for 6months
im looking for oil pressure tester and what sort of pressure should i be seeing,
garry_noble
Re: mk6 transit rebuilt
Postby karl » Fri Jul 17, 2015 7:12 pm
air locked :D
take sensor out and make sue oil is coming out
karl
Tranny Lover!!!
Postby garry_noble » Fri Jul 17, 2015 7:24 pm
Sensor air locked?
I'm going remove sensor tomorrow oil should come straight out with engine running Im assuming otherwise I'm going be covered ain't i
garry_noble
Postby garry_noble » Fri Jul 17, 2015 7:30 pm
I meant engine off
garry_noble
Postby davew2 » Fri Jul 17, 2015 7:35 pm
Can you disconnect wire from sender if light goes out its sender
If it ain't got leaf springs it in't a commercial
davew2
Postby karl » Fri Jul 17, 2015 7:39 pm
i always make sure oil light goes out well before injectors are fitted as you can hear un wanted sounds within the engine
it a golden rule for me
put i put me money on it air locked
karl
Tranny Lover!!!
Postby davew2 » Fri Jul 17, 2015 8:04 pm
Karl how i read it hes saying it stays on when engine is turned off am i wrong :?
davew2
Postby karl » Fri Jul 17, 2015 8:15 pm
davew2 wrote:Karl how i read it hes saying it stays on when engine is turned off am i wrong :?
ok he aint being specific :( of the problem is it on running or is it on when not :roll:
karl
Tranny Lover!!!
Postby garry_noble » Fri Jul 17, 2015 8:15 pm
Air lock I don't understand how can u stop that?
Once running oil light remains on turn off restart still remains on.
I'm going remove sensor tomorrow I h vae another one but going do pressure test any way ... engine isn't tapping so oil must be getting up top
garry_noble
Postby karl » Fri Jul 17, 2015 8:19 pm
garry_noble wrote:Air lock I don't understand how can u stop that?
so to sum this up you have engine running and the oil light is permanently on :?:
before engine rebuild oil light always went out :?:
so the only thing i can think of it their is an air lock with the oil cooler :D or as op has said oil switch is faulty
karl
Tranny Lover!!!
Postby garry_noble » Fri Jul 17, 2015 9:13 pm
I have no idea if oil light went out prior to rebuild as it was non runner...... but oil failure wasn't the cause of non running.......
Yes correct when running oil light remains on...... but engine doesn't sound tappy being this is first time it's been started since rebuild
How can I clear airlock then?
garry_noble
Postby karl » Fri Jul 17, 2015 9:16 pm
garry_noble wrote:I have no idea if oil light went out prior to rebuild as it was non runner...... but oil failure wasn't the cause of non running.......
remove the pressure switch till oil runs out not running thow basically gravity feed the system
karl
Tranny Lover!!!
Postby garry_noble » Fri Jul 17, 2015 9:27 pm
Ok I shall try that tomorrow I shall get pressure tester from someone just incase.....
garry_noble
garry_noble
Postby bangertrack » Sat Jul 18, 2015 7:16 am
Best option is to connect a gauge. I would guess oil pressure at idle / cold oil greater than 20psi (probably considerably more) but have never measured it. Oil pressure should register within a second assuming the oil filter is full from having been run already. Airlocks not an issue in pressurised oil system.
No good just having oil flow from sender hole - possible to have flow and no pressure (if a main bearing shell was missing, for example).
Previous post suggests method for checking the pressure sender.
May be worth removing the injectors if oil pressure not achieved within 2 seconds with the pressure gauge fitted for the subsequent investigation.
bangertrack
