bigger steel wheels
bigger steel wheels
Postby ParkerBear86 » Sun Jul 19, 2015 11:31 am
hello,
quick question about wheel size looking to change my 15 " steel wheels to 16" with 215 70 r16 tyres there are off another transit mk6 not sure on model think it was rwd anyway been informed by a friend that they are not compatible with my van 85 260 fwd is this true ?
thanks
phil
ParkerBear86
Re: bigger steel wheels
Postby wojciech » Sun Jul 19, 2015 2:13 pm
For all Mk6 Transits with 15" wheels you can use without problems 16" wheels from Mk6/Mk7.
My Transit Mk6 125T300, purchased in Germany, has written in original papers (in Fahrzeugbrief) two sizes wheels: 15" with tyres 195/70R15C102R and 16" with tyres 195/65R16C102R.
Oposit replacement (16" -> 15") can be sometimes impossible...
wojciech
Postby Altransit » Sun Jul 19, 2015 2:18 pm
As said above, there's plenty of room for the bigger wheels/tyres on your 260, but the speedo readings will be wrong, and tell you that you're going slower than you are :mrgreen:
Postby wojciech » Sun Jul 19, 2015 2:21 pm
Altransit wrote:A but the speedo readings will be wrong, and tell you that you're going slower than you are :mrgreen:
But he can buy tyres with lower profile - as in my example... Both have exactly the same diameter and speedo works correctly.
wojciech wrote:15" with tyres 195/70R15C102R and 16" with tyres 195/65R16C102R.
wojciech
Postby Altransit » Sun Jul 19, 2015 2:25 pm
Yes, I realise that, but he's asking if he can use 215/70/16 tyres which are already on the wheels (I presume) :wink:
Postby wojciech » Sun Jul 19, 2015 2:30 pm
Altransit wrote:Yes, I realise that, but he's asking if he can use 215/70/16 tyres which are already on the wheels (I presume) :wink:
Oh, no... Tyres 215/70R16 for 85T260 are much much to much (+4,8%). It will look very bad... :cry:
wojciech
Postby Altransit » Sun Jul 19, 2015 2:41 pm
wojciech wrote: Oh, no... Tyres 215/70R16 for 85T260 are much much to much (+4,8%). It will look very bad... :cry:
It doesn't look bad at all on a SWB ...........................
Silver van in middle has 215/75/16, white vans both have 195/70/15. The bigger tyres just fill the arches better :)
Postby Altransit » Sun Jul 19, 2015 2:51 pm
Plenty of room to fill the wheel arches with a bigger tyre, and this van is loaded :D
Postby ParkerBear86 » Sun Jul 19, 2015 3:33 pm
Thank you Wojciech & Altransit for replys gonna be honest reason i bought wheels is i thought they would fill arches up a little more 15's look a little silly to me the photo with silver van is the look what i am after :)
will post some pictures when fitted you can give me your verdict.
thanks again
phil
ParkerBear86
Postby dethleffs » Mon Jul 20, 2015 10:06 pm
My camper van was fitted from new with 16 inch rims with 215/75/16
It's a FWD 140 MWB 2009 350
One life, live it
dethleffs
Postby ake » Tue Jul 21, 2015 6:59 am
dethleffs wrote:My camper van was fitted from new with 16 inch rims with 215/75/16
All 330 and 350 are fitted with 16" wheels
All 250, 260, 280, 300 are fitted with 15" wheels
Except the 280 Econetic which has 16" wheels ( but it's actually a down rated 330)
Regardless if front or rear wheel drive
Not including alloys!
