Rear wiper
Rear wiper
Postby pcatterall » Mon May 28, 2007 8:58 pm
As my van now has rear windows I thought that a wiper would be nice.
I have tried a search on this subject but am getting nowhere.
There is a dished shape in the lower part of my hi roof doors plus a rubber grommet. Is this where a wiper motor could be fitted?? if so it looks like the spindle would have to go through the bonded rear window.
Is this possible.
Thaks guys.
Regards
pcatterall
Postby MrMPuk » Mon May 28, 2007 9:03 pm
Is it a tail gate or twin doors?
Postby motorwise » Mon May 28, 2007 10:33 pm
they do have wipers on tailgated and double door versions so it should be possible - depends how much you want to spend - second hand bits may be hard to find - good luck
http://www.motorwise.net
motorwise
Postby mainroaduk » Mon May 28, 2007 10:41 pm
Got wipers on my doors, and yes the spindle goes through the glass.
mainroaduk
Postby 100 T280 » Mon May 28, 2007 10:43 pm
You'll need the glass with the hole already there for the wiper spindle, door harness (main loom in D pillar should have the wiring in place) and wiper stalk with rear wipe control on. There isn't much that doesn't just plug in and work on a mk6 :P
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby stevo » Thu May 31, 2007 7:43 pm
Wouldnt it be easier to just put an indepedant switch on the dash rather than change the wiper stalk?
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Postby planet1 » Thu May 31, 2007 9:31 pm
try getting a new wiper kit from a boat dealer. they are reasonably cheap and most can be programed for path sweep etc. should be easy enough to plug into existing wiring?
planet1
