gear change !
gear change !
Postby bertsta2002 » Wed May 30, 2007 7:19 pm
ive had a new 06 gearbox in my o1 transit 260 fwd for about 3 weeks everything was running smoothly , until today when i noticed when changing thru gears i can feel a slight notch as it pass's thru neutral from 1st to 2nd and so on , all the gears .anyidea whats causing this, i can feel it in my hand on the lever yet theres no change in how it drives , thanks brett
bertsta2002
Postby MrMPuk » Wed May 30, 2007 10:34 pm
So is it a problem?
Postby bertsta2002 » Thu May 31, 2007 4:26 pm
not at the moment , but ive had to replace a gearbox and newer drive shafts to fit , so u can understand when things start to feel different my ears perk up :D (im concerned because maybe it could become a problem)
bertsta2002
