paul2012 wrote:I will upload a pic of mine tomorrow with details for mk7 doors to mk6
Only the O/S mk7 door loom require a slight modification to work properly on a mk6
Did you manage to get a picture.
Alynjones9 wrote:paul2012 wrote:I will upload a pic of mine tomorrow with details for mk7 doors to mk6
paul2012 wrote:Alynjones9 wrote:paul2012 wrote:I will upload a pic of mine tomorrow with details for mk7 doors to mk6
I've not long got back in & too dark to take pic. Will do 1st thing in the morning & post it up
paul2012 wrote:Details for wiring elec windows /central locking using mk7 door looms on a mk6
On mk7 door loom plug. Located pins 12 & 15. Both of these are GND.
Pin 12 in the main GND on mk6 for elec windows & central locking & on mk7 for elec windows
Pin 15 is GND for central locking on mk7.
Strip away some insulation on the wires on pin 12 & 15. CONNECT them together & solder joint. Finally insulate, job done.
This is only required on drivers door. Passenger side does not require any modification.
TransitSAVO wrote:Is there a way unlock all doors at same?
TransitSAVO wrote:if front doors was open first then start engine, is there a way to open rear compartment?
