Hi all
Looking for some help on a smoky van problem and you guys seem to know your stuff so how about some advice?
The van is a camper on a '55 reg transit 350 125ps which has hardly worn the polish off the tyres but 'cos I bought it in Germany Ford aren't too interested in warranty work. Not that the local dealer is much use anyway (except at running up big invoices).
We've just got back from a three week trip to France and on the third day over the water the van starts chucking out vast clouds of black smoke when I give it some wellie. The smoke is also evident at cruising speed, but not so pronounced. I put it down to a duff batch of diesel at first but it didn't clear after the next fill-up so checked in at the local French Ford Dealer. "Ah oui oui sir - leave it with us for a few of days so we can diagnose your problem" - fat lot of use when you're a few hundred miles from home! Anyway, they seemed to think it wasn't critical so we carried on with the trip and polluted half of France.
Back home now and need to sort the problem, preferably with minimal reference to the cash guzzling Ford dealer. Reading here I see lots of references to the EGR valve? is this a likely cause? What's the best way to diagnose and sort the problem, seems that crimping the vacuum pipe to the valve might help?
Thanks in advance for any suggestions.
BTW: I did check the air filter etc. for obstructions - and the van is performing well enough - better than usual if anything.
