Hi All,
New to Transit ownership, we have picked up a 2003 100 280 (2.0D MWB, FWD) with a modest mileage. She's not the most undented Transit out there but everything appears to work as it should.
Whilst having a detailed rummage around the engine bay I have found a pipe which appears to go to nowhere. It starts at the timing end, runs along the block and around the back of the block and it's flanged end is attached to nothing! It appears to be alloy and has heat shielding on. See pic, I hope it's clear enough.
I also found what appears to be a vacuum pipe hanging ie not attached to anything either end near to the positive battery point.
Notice too the three way plumbing fitting used on the coolant hoses (cream coloured just underneath the rad hose)!
Anybody any ideas? It runs fine by the way (touch wood).
