One pair of injectors are held down by a single clamp with just one long skinny bolt, which is probably why they are prone to coming undone and leaking.
Remove the bolt, take off the clamp, remove the wiring connector, fuel inlet and leak off pipes, and the injectors will just pull out.
If the sealing washer doesn't come out with the injector, you'll need to fish around in the bottom of the aperture to remove it. If it looks in good condition, you'll get away with just replacing it with a new one, if not, you'll need to gently ream out the base of the aperture before replacing the washer. Do this for both injectors of the clamped pair.
Refit the injectors, and the clamp, using a brand new bolt, do NOT re-use the old one, make sure you clamp it down tight, but do not overtighten. Replace connector, diesel pipes, and anything else you've removed, and the job is done
I just did the one pair on mine, but I have the parts ready to do the other pair if either of them start leaking
