My older (94) camper has just had to have quite a bit of new floor welded in, can't complain after 13 years though. Main problem seems to be water getting under the underseal and poor sealing between the floor and the 'chassis'.
Just been under my 'new' 2001 van to check her out. Things don't look too bad but there is evidence of surface rust starting. (no underseal has been applied)
Question is what if anything can/should be done to keep the dreaded rot away bearing in mind that some rust is evident.
Apply underseal? Use waxoil? Try to treat existing rust first with 'rust convertor'
Most grateful for your advice guys.
