silly question about changing gear
Postby snatch69 » Thu Jul 05, 2007 5:28 pm
i know that you need to push the gear stick down to select reverse , but do i need to push it down when changing between other gears? silly question i know , but just curious
snatch69
Postby mrgasoil » Thu Jul 05, 2007 5:29 pm
nope :wink:
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby sc_BK » Thu Jul 05, 2007 6:21 pm
...you don't have to push down to get reverse? :?
sc_BK
Postby MrMPuk » Thu Jul 05, 2007 6:25 pm
sc_BK wrote:...you don't have to push down to get reverse? :?
I was thinking that!
Postby mrgasoil » Thu Jul 05, 2007 6:37 pm
hmm, come to think of it.....you don't :lol:
mrgasoil
Postby KiloKilo » Thu Jul 05, 2007 6:37 pm
With a 5-speed you can shift like normal and with a 6-speed you need to push or pull to get into reverse. (at least with the Mk7)
KiloKilo
Postby MrMPuk » Thu Jul 05, 2007 6:38 pm
I believe snatch has a 2001 Mk6.
Postby KiloKilo » Thu Jul 05, 2007 6:40 pm
MrMPuk wrote:I believe snatch has a 2001 Mk6.
I did not know
KiloKilo
Postby MrMPuk » Thu Jul 05, 2007 6:41 pm
I did not know
No me neither, I had to look back through old posts.
Postby Dan T » Thu Jul 05, 2007 6:57 pm
I have to push down to select reverse on my van but on my works van i don't :roll: is it somthing to do with fwd and rwd :?: or even the year of production :?:
Dan T
Postby MrMPuk » Thu Jul 05, 2007 6:59 pm
Dan T wrote:I have to push down to select reverse on my van but on my works van i don't :roll: is it somthing to do with fwd and rwd :?: or even the year of production :?:
Is one FWD and the other RWD? Are they both Mk6's?
Postby Dan T » Thu Jul 05, 2007 7:05 pm
Both are mk6. mine is fwd and the works is rwd
Dan T
Postby Nighthawk » Thu Jul 05, 2007 9:25 pm
pre 2004 front wheel drives needed the lever pressing down in order to get past the reverse block
post 2004 the design was changed and the press down was deleted.
rear wheel drive has never needed the reverse block on either 5 or 6 speed.
Transit.........Job done
Nighthawk
Postby sc_BK » Thu Jul 05, 2007 10:20 pm
Well I have a 2000 FWD and I don't have to press the gear stick down :P
sc_BK
Postby stuartadair » Fri Jul 06, 2007 8:02 am
I'll add my bit...
I do have to push down on my 2001 Tourneo but recently had a 2006 Tourneo on hire that I didnt have to push down.
I reckon the man in-charge of gearboxes at Fords just chops and changes depending on the mood he is in :D
Stu
stuartadair
