mk7 wiring questions?
Postby adamv6 » Fri Jul 06, 2007 9:08 pm
85/260 mk7 07 plate
i need to find an ignition switched wire to run my inverter in the back, doesn't need to carry many amps as i can run it through a relay.
also i'm thinking of putting my amp in and wondering if there is any rca/aux out from the standard 6000cd radio.
adamv6
Postby Azer van man » Fri Jul 06, 2007 10:52 pm
you can by an aux lead from fords for about £8 but you have to ask for an auxilliary lead for a ford fusion as they dont recognise it for the mk7 tranny :?
Azer van man
Postby adamv6 » Sat Jul 07, 2007 8:49 am
will that have rca leads on it do you know
adamv6
Postby Azer van man » Sat Jul 07, 2007 6:04 pm
Dont mean to be ignorant but what are rca leads :? If you put ford aux into search/buy on ebay it usually has a few on there for sale hope that helps :)
Azer van man
Postby adamv6 » Sat Jul 07, 2007 6:42 pm
i've had a look and it seems that the aux adapter lead has a stereo jack input.
i need to get an output from rca's (phono plugs) but it seems that this isn't an option.
looks like if i want to connect an amp then i'd have to use the speaker outputs.
thanks anyway Azer.
adamv6
Postby pippin » Sat Jul 07, 2007 10:41 pm
You can buy leads that have a 3.5mm stereo jack plug on one end and two phono plugs on the other. Or any combination of plugs/sockets to match.
pippin
Postby adamv6 » Sun Jul 08, 2007 9:24 am
thanks pippin but the aux lead with the jack input is an input into the radio, i was looking for an output for an amp.
adamv6
Postby pippin » Sun Jul 08, 2007 9:44 am
Yes, sorry - should have realised.
pippin
Users browsing this forum: Google [Bot], Google Adsense [Bot], knobby1
