Error codes P251A and P2563
Postby Kristianskaffe » Sat Feb 11, 2017 6:15 pm
Hello everyone,
Well my newly bought Transit is sick in some way... My mechanic has ruled out the head gasket, so that´s a relief.
But some codes keep coming back and some cant be deleted. See picture in danish :)
P251A - power take off enable switch circuit/open
http://carerrorcode.com/p251a
P2563: Turbocharger boost Control position sensor Circuit range/performance
Status-72 (actuator stuck open)
Status-6F (No valid status available)
My mechanic says that there is absolutely no power when getting around 3. og 4. gear... after restart it´s back again. I can see by looking through the threads, that it is common, but I can´t see that there is a definitive fault... or is it the PRV and SCV problem... I´ve got the parts in my Ebay-basket... Is it a go?
http://www.ebay.co.uk/itm/321617865886
http://www.ebay.co.uk/itm/201724714341
I have an IDS on the way and it has left China! I can read that I should wait and do a PCM-update before anything else? I can also read that some have had succes by replacing the EGR? As I have ordred a blanking plate and the IDS is on the way, should I then wait for that, before I do anything with the EGR? By this, the IDS should do the trick? http://vantuner.co.uk/transit-egr-delete/
Please guys, hope you will help me in sorting this out :)
Have a great evening!!
Kristian
http://www.kristianskaffe.dk
Follow me here and see what I´m fooling around with :D
https://www.instagram.com/kristianskaffe.dk/
2006 Transit undergoing makeover and refurb :D
Kristianskaffe
Re: Error codes P251A and P2563
Postby paul2012 » Sat Feb 11, 2017 7:45 pm
Kristianskaffe wrote:Hello everyone,
Kristian
P251A PTO Enable Switch Circuit / Open
- disregard that one. Down to PCM Calibration
P2563 Turbocharger Boost Control Position Sensor "A" Circuit Range/Performance
- Check elec actuator on turbo & variable vanes (Common to seize up due to carbon build up)
Above has nothing to do with PRV or SCV :idea:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby kristiank » Sat Feb 11, 2017 7:50 pm
Thx!
kristiank
Postby Kristianskaffe » Sat Feb 11, 2017 8:05 pm
Thank you very much!
I´ve seen on other posts that the actuator can be the problem, but I´m not sure if I know what variable vanes means. Do we take the turbo apart og is it down to outside moving parts?
Kristianskaffe
Postby Kristianskaffe » Sat Feb 11, 2017 8:11 pm
Kristianskaffe
Postby Kristianskaffe » Sat Feb 11, 2017 8:24 pm
Is it possible to clean and lubricate it?
I cant seem to find a new or refurb. actuator other than this one, but I´m not certian it will fit the 2.4 TDCI, 140 RWD
http://www.ebay.co.uk/itm/Turbocharger- ... SwYlJW3qL0
Kristianskaffe
Postby loot » Sat Feb 11, 2017 9:47 pm
You have a mk7 140ps so you have an electronic vnt turbo and not the vacuum type.
This is yours. :arrow:
Ids map here
loot
Postby loot » Sat Feb 11, 2017 9:50 pm
Ids map here
loot
Postby Kristianskaffe » Sat Feb 11, 2017 10:06 pm
Since it´s electrical, and I have the errors I do... what are the chances of fixing my current one? Can it be taken apart and cleaned and so?
Or would you recommend getting this one right away?http://www.ebay.co.uk/itm/Ford-Transit- ... SwPCVX~PoO
I don´t suppose I need to go for the whole package, as I cleary heard the turbine/ambulance noise from the turbo :D
Kristianskaffe
Postby Kristianskaffe » Sat Feb 11, 2017 10:17 pm
Well... they don´t ship outside UK I see :(
Kristianskaffe
Postby loot » Sat Feb 11, 2017 10:33 pm
You can check yours and remove the cover to see if there is anything obvious that is stopping it work, also when you disconnect the arm you can move the rod to the turbo and see if it moves smoothly etc.
Turbo shouldn't make the siren noise although i don't think it means immediate problems.
Strip and clean before replaced.
Ids map here
loot
Postby Kristianskaffe » Sat Feb 11, 2017 10:52 pm
Thanks a lot, means so much :D
About the siren... I had that in my Galaxy, and that was a brand new 2.0 TDCi back then. My children thought that there was an ambulance coming all the time... :)
Kristianskaffe
Postby loot » Sat Feb 11, 2017 11:00 pm
Yes i did on my mk7 transit 140 the turbo itself felt OK when i span it but i found the triangular gasket was black on 1 side so i believe it was blowing and causing the sounds, i did replace the whole thing and never heard it again 8)
Ids map here
loot
Postby ned » Sat Feb 11, 2017 11:21 pm
loot wrote:Yes i did on my mk7 transit 140 the turbo itself felt OK when i span it but i found the triangular gasket was black on 1 side so i believe it was blowing and causing the sounds, i did replace the whole thing and never heard it again 8)
Now that is interesting sometimes mine sounds like a siren other times it whistles, when started from cold you cam smell exhaust fumes in the cab till its up to temp so I might check the gasket out, do they bolt from on top or below?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sat Feb 11, 2017 11:50 pm
Both lol iirc, this 1 is mk7 140ps turbo, yours may be quite different :-)?
Ids map here
loot
