MK7 Drivers side rear door loom
Postby bcraven2 » Thu Feb 16, 2017 5:18 pm
Hi,
some B*****d has cut through the rear drivers side loom :x , just wondering if any of the mk7 rear door looms can be used to replace it. Looking around i cant seem to find the exact part number i have on this loom (6c1t-18c394 LE)
I have found looms that match the number 6c1t-18c394 but they have different letters such as 6c1t-18c394 LF or LB will any of these work?
Thanks in Advance.
bcraven2
Re: MK7 Drivers side rear door loom
Postby bcraven2 » Fri Feb 17, 2017 1:41 pm
or does any one know the pin outs on the 2 multi plugs on the body side of the loom to the 1 multiplug within the back door?
bcraven2
Postby ake » Sat Feb 18, 2017 4:53 pm
I'm pretty sure the other part numbers will work
Postby bcraven2 » Sat Feb 18, 2017 5:53 pm
well ive been to look at a couple of looms which were same part number but with different 2 letters (LH and CA), both of these looms were from mk 7's but had 9 pins on the door lock side of the loom where as the loom i have only has 8 pins, also the looms i looked at were colour coded and the one i have is just 8 solid black wires.
pics of my loom attached
multiplug to door lock:
2 Multiplugs that connect behind rear light cluster:
Thanks.
bcraven2
Postby midnight » Mon Feb 20, 2017 9:07 pm
Hi, I've only just joined this forum an I am currently chasing down a central door locking fault with the rear doors of my van. I have a similar loom to the one that you have. There is eight wire's at the lock end and on the other end behind the rear lights the wires go to two separate plugs. one plug has five wire's and the other has three wire's. All of the eight wire's are black. The number on my loom is 6C1T-18C394 LC. Are you thinking of joining the wire's up. If you are then you maybe in luck as I have not yet had a chance to check the integrity of these wire's in this part of my loom. I am planning to check this part of the loom in the next few day's if it helps.
Ford Transit mk7 2007 145 T300 mwb shr rwd petrol/lpg
midnight
Postby midnight » Wed Feb 22, 2017 11:09 pm
This is what I have. If you do not understand my drawing or if you have any questions then contact me and I will do my best to help. Please understand that anyone who uses it does so at their own risk.
midnight
Postby mswgroup » Sat Dec 15, 2018 8:40 am
Worked for me thanks midnight for the drawing !!!!
51 350 2.4 lwb 125 rwd
56 300 2.2 mwb 110 fwd
mswgroup
Postby TheLastZombie » Sun Apr 18, 2021 10:08 pm
midnight wrote:This is what I have. If you do not understand my drawing or if you have any questions then contact me and I will do my best to help. Please understand that anyone who uses it does so at their own risk.
Sorry for resurrecting an old thread, but thank you for this! I've just had the same issue with our van where the cables had been hacked through and the central locking is now working again.
TheLastZombie
Postby yachtmustang » Sun Oct 24, 2021 11:12 pm
Another late entry into this thread. Keen to understand how Midnight figured out the wiring connections as I have a slightly different setup on my 2013 Transit. I have attached pics of the two connectors in the rear light cluster - all of these wires go into the drivers side door. The two heavier gauge wires in the bottom pic go to the window heater but the other five wires go to the connector for the remote door lock and I can't see what connects where. Bizarrely, there is also a wire that goes from the remote door lock connector to the window heater - no idea why?
Thx for the help
yachtmustang
Postby tranmx2 » Mon Oct 25, 2021 12:27 am
2012 RWD Rhs rear cluster lights locks wires
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS E5 DPF BCM PCM RCM
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP.
There's more letters after a Transit than a military man :lol:
tranmx2
Postby yachtmustang » Mon Oct 25, 2021 7:13 am
Thx tranmx2. I think this is getting me there. Do any of your black wires go to the heated rear window as two of mine do from the grey connector in the pic. I then have five black wires going to the door lock connector but have no idea which which goes to which terminals on this connector. Any clues as to how to figure this out? Thx heaps. Chris
yachtmustang
Postby tranmx2 » Mon Oct 25, 2021 10:28 am
There are no windows in my van's back doors.
I have an image (video) of the black wires at the drivers door which are connected to coloured wires.
I have the image (video) of the rhs rear cluster and lock wiring. So I have two lots of info' as to which black wire is connected to which coloured wire at the front and back of the van.
Next I'd access the lock(s) and see which coloured - black wire goes to/from/on the lock.
My next move would be to find the harness behind the drivers seat area and look for the coloured wires seen at the back or front. The harness could go along near the top of the roof or along underneath on the chassis.
After that I would look in the area of the fuse/relay board to find the coloured wires there.
Much easier to do with a wiring diagram. I'd look on the internet for relevant info'. Look in the Haynes manual for their diagram even if it is for an older model. Sometimes there is info' from a manufacturer of that type of system.
Sometimes I look on the camper van forums.
One needs to look for info' and look on the van to find what goes where.
Ford made a big mistake to not issue wiring diagrams. Had I known the info' was not available I'd have looked for a vehicle that has the info' available to carry out repairs.
So a picture is built up / drawn of what goes where in/on the van by looking at different areas. You may not find all that is required but you'll find a lot of what you need to know. A DMM - or wires with battery and a lamp - can be used to check for continuety. Continuety may not show where there is a electronic unit or switches in the circuit - on modern vehicles putting more than 5 V on a circuit can cause problems so one needs to be very sure that it is only the wires that one is applying V to.
14 yrs ago when I got an Audi A6 that did not work I used info' for BMW and any other info' I could find to - find the faults. Eventually I got info' for the A6 - it still works at 26yrs old.
Manufacturers have been known to change the wire colours en route.
Without a wiring diagram there is but two choices - stealership - do it yourself.
tranmx2
Postby tranmx2 » Mon Oct 25, 2021 11:11 am
Just seen your post in the other post re loom back doors.
Perhaps on Thursday this week I'll be able to remove the back door lock off my van.
So can show which coloured wire goes to which black wire and which black wire is connected to where on the lock.
I think on youtube is a vid of fitting a plate on the door/frame to prevent the wires being cut in the tubes betwixt frame and door.
tranmx2
Postby tranmx2 » Mon Oct 25, 2021 10:52 pm
Opened the rhs rear cluster and got inside the door.
Could not get the lock unit out with out taking more things off. Did get the connectors and harness/wires out to look at and used the DMM for continuity twixt - coloured - black - coloured wires.
tranmx2
Postby yachtmustang » Tue Oct 26, 2021 2:24 am
That is amazingly helpful. Thx so much for making the effort and sharing. Much appreciated.
yachtmustang
