jasons wrote:Found a leak on top of the filter housing,but stillno better,any ideas .No check light on and runs the same as normal once it starts.Jay
Ive put another fuel filterhousing on it today seems better but the test will be in the morning.Do they suffer from filter housings letting in air because all the symtons are like the fuel is draining back.Thanks Jaymotorwise wrote:jasons wrote:Found a leak on top of the filter housing,but stillno better,any ideas .No check light on and runs the same as normal once it starts.Jay
well if diesel can get out, air can get in - you're probably suffering a bit of drain back - did you fix the leak?
jasons wrote:Ive put another fuel filterhousing on it today seems better but the test will be in the morning.Do they suffer from filter housings letting in air because all the symtons are like the fuel is draining back.Thanks Jaymotorwise wrote:jasons wrote:Found a leak on top of the filter housing,but stillno better,any ideas .No check light on and runs the same as normal once it starts.Jay
