What should Anti-stall rpm be? It shoots up to 1200, where our work 12 plates only rise to 1000 and fairly gently at that.
Is it just a case that it needs update(s) and the learns done - it's got 250K showing and no record in the service book of any such thing, had independant sevicing from new by the looks of it and recipts for/listing everything.
If it helps any, there is another small issue, if you rev it hard through the gears - it's limited to 70, so like to give the Cat a toasting every now and again - between 3rd and 4th there's a slight hesitation as you get back on the gas after changing up. Cleaning the MAP reduced this but not fixed. Turbo actuator appears free but not stripped it to check due to work being V busy.
Not a problem to put new PRV and SCV on, but I'm a great believer in leaving things be if they ain't going wrong.
Jim
