bambi mk 1 wrote:You must have changed the bolts ,they are at least 4 inches long
godderidge wrote:As far as I know about the 6 speed rwd boxes in the Mk 7 , is from 2006 one box then in 2008 some internals changed ,but box will still fit also in 2008 a 2nd box produced for the 3.2 with a bigger bellhousing to accommodate a bigger clutch this gearbox will fit the 2.4 if you have the longer bolts but the 2.4 gearbox will not fit 3.2 if you want to keep the original clutch ,but you could fit the smaller clutch I guess, whether it will handle the power I don't know,then when the euro 5 engine came out the 3.2 gearbox was fitted to all rwd vans
bambi mk 1 wrote:godderidge wrote:As far as I know about the 6 speed rwd boxes in the Mk 7 , is from 2006 one box then in 2008 some internals changed ,but box will still fit also in 2008 a 2nd box produced for the 3.2 with a bigger bellhousing to accommodate a bigger clutch this gearbox will fit the 2.4 if you have the longer bolts but the 2.4 gearbox will not fit 3.2 if you want to keep the original clutch ,but you could fit the smaller clutch I guess, whether it will handle the power I don't know,then when the euro 5 engine came out the 3.2 gearbox was fitted to all rwd vans
+ the csc is different on the long bolt box and was a Ford only item the last one I replaced a short time ago
