P062D Fault Code
P062D Fault Code
Postby DCha10 » Mon Oct 02, 2017 11:36 pm
Getting this code on my transit now as it won't start
fuel injector driver circuit performance bank 1
Have tested the injectors with noid light and nothing...
all connections fine, no broken wires that i can see..
Faulty ECM?? does this mean changing the Ecu?
DCha10
Re: P062D Fault Code
Postby knobby1 » Tue Oct 03, 2017 2:43 am
Mk6..?? or Mk7..??
Postby DCha10 » Tue Oct 03, 2017 6:56 pm
Mk7
2012
2.2
DCha10
Postby knobby1 » Tue Oct 03, 2017 11:43 pm
DCha10 wrote:Mk7
2012
2.2
Is she a Euro-V..??
Could be many things....You might need to check all the wiring/plugs to the PCM. The loom can be broken/damaged inside without actually looking bad....a continuity check is simple and costs nothing..!
Postby DCha10 » Wed Oct 04, 2017 2:43 pm
I take it it’s located behind The passenger headlight?
Yeah it’s Euro 5
DCha10
Postby DCha10 » Wed Oct 04, 2017 5:32 pm
Have just done a continuity test and all is good....
Is it unheard of for the ecu to fail?
DCha10
Postby knobby1 » Wed Oct 04, 2017 7:50 pm
DCha10 wrote:Have just done a continuity test and all is good....
Possible but unlikely, well... it's not common at least. Have you checked all fuses and relays etc...??
Postby DCha10 » Wed Oct 04, 2017 9:16 pm
Yeah all fuses and relays fine...
All connections spot on, not corroded or anything...
DCha10
Postby Rob14 » Wed Aug 11, 2021 8:13 am
hi , i have same dtc on my 2014 2.2 custom no start P062D have you managed to fix yours? thank you !
Rob14
