I also have some suspect wires under the dash near the steering column.. Theses no way ford would crimp wires together and just tape it is there?Jbaussie wrote:I'm pretty much at the same point as you... Still no central locking...
How often does the module fail? Only time I dont blow a fuse is when it's disconnected..
For the sliding door... Have u tried turning the inside knob on the bottom-left of the sld? I had to take the side cover off and pull the wire while fiddling with the turn knob thing lol...
Once all door connections are disconnected is our next step to test each wire with a multimeter?
Sent from my SM-G935F using Tapatalk
