Mk7 mid-rev light-throttle judder issue 1500-1700 revs
Re: Mk7 mid-rev light-throttle judder issue 1500-1700 revs
Postby Shankie » Mon Jan 29, 2018 6:51 pm
DAZZ wrote:
Shankie wrote:So, if perhaps it's a temperature thing, maybe replacing temperature sensors is an idea? There's the Manifold Absolute Pressure and Temperature sensor. I could replace that – it's cheap and easy. Any other temperature sensors that could be involved?
I've not replaced the sensor on mine, but it gets cleaned once a year when I service the van, hasn't made any difference, BUT I might try replacing it next time.
As it monitors manifold pressure and temp, I wonder if it's becoming less sensitive through age and not responding to the actual pressure changes quick enough??
Just been looking at MAF sensors too, they're not to dear either, wonder if it be worth swapping this too?
I also did wonder if it could be anything to do with winter additives in diesel too if they still put them in??
Yeah that's what I'm thinking. Sensors are cheap and easy to do.
Interesting idea about winter diesel. This suggests that winter diesel is required by law in the colder months https://en.m.wikipedia.org/wiki/Winter_ ... prov=sfla1
Sent from my ONEPLUS A5000 using Tapatalk
2007 Mk7 Transit, 85 PS FWD
Shankie
Postby Altransit » Mon Jan 29, 2018 7:31 pm
I don't think it's Winter diesel, mine has been doing this for months, well before Winter.
Do you have a link, or a part number for the sensors :?:
Postby Shankie » Mon Jan 29, 2018 9:09 pm
A bit of Googling turns up these as the MAP and MAF sensors. Can someone here (Martyn please help!) confirm whether these are the right ones? And whether they're likely to be at fault?
https://www.ebay.co.uk/itm/NEW-GENUINE- ... SwImRYHfGx
https://www.ebay.co.uk/itm/GENUINE-FORD ... 1209570725
Shankie
Postby knobby1 » Mon Jan 29, 2018 11:37 pm
Shankie wrote:A bit of Googling turns up these as the MAP and MAF sensors. Can someone here (Martyn please help!) confirm whether these are the right ones? And whether they're likely to be at fault?
The MAP & MAF sensors rarely fail, but not impossible I guess.
Postby Airthies » Tue Jan 30, 2018 1:32 am
I've got two vans the same. One does it one doesn't.
I'm in the process of swapping items one at a time to see if I can narrow down the fault. Rather than swapping out and fitting new I should hopefully be able to transfer the fault for a better confirmation of the culprit if it's an external sensor rather than a physical component of the engine.
As my way it don't expect it to be a quick process was ill give each item a while to test.
First item was throttle pedal.
Result? No change so far!
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Shankie » Tue Jan 30, 2018 10:46 am
If anyone is going to solve this issue, it's Arthies. Not many of us have the luxury of being able to swap parts! I don't think I'd be popular around the house if another van showed up...
Shankie
Postby DAZZ » Tue Jan 30, 2018 11:32 am
I just put "2.2 tdci juddering" in Google out of interest, it's not only transits that are suffering..... Mondeos, Smax's, again with no real resolution?
2008 mk7 280 85 Crew cab - poverty spec :lol:
Replaced with......... a 300c estate :lol:
now sold, the judder did me ed' in :lol:
suppose my 350z and hayabusa will have to do for now :twisted:
DAZZ
Postby Airthies » Tue Jan 30, 2018 11:49 am
Shankie wrote:If anyone is going to solve this issue, it's Arthies. Not many of us have the luxury of being able to swap parts! I don't think I'd be popular around the house if another van showed up...
thing is, it's wife's van that's doing it so it's not really bothering me right now
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Bluecjw1234 » Sat Mar 31, 2018 10:45 pm
Anymore updates please
Bluecjw1234
Postby Shankie » Sat Jun 09, 2018 2:05 pm
I just came here to ask the same thing. I've done a pump and pilot learn. No dice. Also, we're now in summer diesel time, so I think we can rule that out.
Shankie
Postby Airthies » Sat Jun 09, 2018 6:40 pm
I changed two injectors and it's running fine.
Can't remember what readings made me change them but defo something in the live data caught my eye that made me try it though wasn't enough to categorically condemn them but enough of a question mark to warrant trying a change.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Shankie » Sat Jun 09, 2018 10:49 pm
Airthies wrote:I changed two injectors and it's running fine.
Interesting. I'll have to get Forscan on it. Last time I looked all seemed fine, but I guess I've only looked at fuel rail pressure.
How did you work out which injectors need changing? I wouldn't be surprised if one of mine is a bit goosed due to the previous owner not putting a copper washer under #1!
Shankie
Postby Airthies » Sat Jun 09, 2018 11:10 pm
First would be a leak off test. Checking how much fuels coming back out the top to go back to tank.
Then check live data and injector related options as can't remember what options are available or best ones to use.
Your looking for anything that doesn't look right. Not much help but get some readings then Google them and see what comes up.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Shankie » Mon Jun 11, 2018 10:32 am
Ok cool thanks Arthies. A leak-off test is definitely the place to start, isn't it.... and not too tricky.
I'll put in on the "big list of jobs" :)
Shankie
Postby tilly » Tue Jun 12, 2018 10:16 am
Mine had a judder at mid revs, when accelerating. I replaced the n/s driveshaft and that judder has totally gone.
Mk7, FWD 110ps GLX in Silver 2007
tilly
