by Eoinom » Fri Aug 24, 2018 2:13 am
Today is the first day I didn't experience the gearbox Shudder (fingers crossed)
Mine is a 07 Mk7 110T300 5 speed 2.2 and all the same issues.
Hesitation at 1500-1800RPM depending on gear before engine gets up to temp almost like slight fuel starvation.
Gearbox Shudder at 1700RPM 50MPG 5th Gear if engine is not up to temp
Hard to start if sitting for a week.
Cold Weather:
Symptoms mainly when engine is cold
Symptoms worse in cold weather(5C) and do not go away under 0C.
Engine very Hard to Start if temp below 0C, eventually coughs, splutters and starts in a cloud of black smoke as if the fuel had waxed up, but engine does eventually start and keeps running but is noisy and clattery like an old vw bus until warm.
Other things I've noticed:
Fuel Guage not working - sometimes shows eratic readings if driving over a bumpy road.
"soot" smell recently started coming from exhaust when cold with a small amount of black smoke when cold - nothing worse than my landy td5 used to do.
Slight engine hunting (3 or 4 times) if clutch peddle pushed down at 1700 rpm.
Recent Fuel Starvation - 5l of diesel from a can in the back didn't help... limped it to a garage 10 miles away, filled up and eventually the van started and ran without a problem - this was either related, or my fuel consumption dropped massively and I ran out of fuel.
All of this only started since I've had my 4 injectors replaced.
Since then I've also had the EGR, EGR Cooler and Injector Rail seals replaced.
IDS showed problem with the fuel sender unit - 2 codes... sorry have lost the sheet - it was diagnosed in Germany with a bad translation as "the fuel pump in the tank has no signal" but okay to drive to Ireland where of course the symptoms go away with the heat.
After getting a stern talking to from a long-term transit driver over the risks to the fuel pump of contaminated fuel, especially with 195k milage, the fuel starvation incident and the heatwave finishing meaning the symptoms returning I eventually bring it to my mechanic back home last week. When they shake the van the voltage changes and the fuel gauge starts to move erratically, but not when they trace the sender wire. Straight away he suspects the BCM - checks it with another 2.2 and finds a voltage difference and thinks there's signs of water damage.
BCM replaced, reprogrammed and the fuel gauge now shows full and the miles to zero shows a number. Fuel tank dropped, drained and cleaned. A quick check of the diesel that came out of the tank and there was black bits of crud at the bottom and a cream "jellyfish" of slime about the size of a jam jar lid floating about about an inch up from the bottom. There was also some slime around the fuel sender unit base and the float arm was rusted in the upright position.
All cleaned out, 20l clean diesel put in and the engine started first time, no smoke and sounded so much smoother than before. No errors in IDS, but they did notice a fluctuation in the fuel pressure - which they think might be the pressure sensor.
Anyhow they've given it back to me to drive - I have to drop it back as they had to do a bodge job replacing the arm on my existing fuel sender unit as the replacement was faulty. They also want to see if the pressure readings bed in with a bit of normal driving, and they didn't have one in stock to test.
I'd asked them to do a fuel pump learn, but I'm not sure if they have - I think they were just glad to get the space back in the garage after sitting there for a week. I just got my modified ELM today and downloaded forscan but I'm a little nervous about going in and doing any of the tests as a first time user. But guess what.... it drove great today. no hesitation, no shutter, and only the normal blip of the engine when you push in the clutch - plus the engine seems to be running much quieter and smoother.... quiet enough for me to now start hearing other noises so now a new hunt begins!
My mechanic reckons that a mix of the fuel sender not priming properly could've caused the hesitation and the sludge in the tank could explain some of the starting problems and why the problems are worse in the cold weather. Only time will tell!
