Mk7 mid-rev light-throttle judder issue 1500-1700 revs
Re: Mk7 mid-rev light-throttle judder issue 1500-1700 revs
Postby DAZZ » Mon Sep 17, 2018 12:17 pm
Shankie wrote:I was wondering whether a remap might make a difference as, if it's a debounce/hysteria issue, it all it might take is a slightly different torque request at a certain point to sort it out.
Well it hasn't cured it totally, but only had a stage 1 map, from 85 to approx 110 bhp, but!! it has really cut down the black smoke when I boot it.....??? :roll:
2008 mk7 280 85 Crew cab - poverty spec :lol:
Replaced with......... a 300c estate :lol:
now sold, the judder did me ed' in :lol:
suppose my 350z and hayabusa will have to do for now :twisted:
DAZZ
Postby Eoinom » Mon Sep 17, 2018 5:40 pm
Ronald53 wrote:
Eoinom wrote:.... and did Pump and Injector Pilot Relearns and none of the symptoms have come back...
I am interested to know if the injector pilot setting needs a special procedure to do the learning. I meanwhile reset the learned parameters for the injector pilot setting twice. For me, this helped to reduce judder. But what is the best method for learning? I didn't see a learning option in Forscan.
Kind regards,
Ronald
Its under Service Procedures. I'm using v2.3.16 of Forscan.
Eoinom
Postby Ronald53 » Mon Sep 17, 2018 7:00 pm
Kind regards,
Ronald
That is where the reset of the pilot injection learned parameters is done. I have been there, done it. I posted the question as I was looking for something similar to this: https://forscan.org/forum/viewtopic.php?p=1353#p1353
Kind regards,
Ronald
Ronald53
Postby DAZZ » Thu Nov 22, 2018 3:02 pm
ahh 2 posts on a similar topic..
DAZZ
Postby twin--turbo » Thu Nov 22, 2018 7:21 pm
Interestingly.... after replacing my 2 dodgyish batteries with to nice big new ones... I have done 20 miles without noticing any part load flutter.
Is it luck?
Is it because the PCM was cleared of drive cycle data??
IS it because battery voltage is now stable???
Is it cured????
God knows, giving it another 70 miles mixed driving before I get hopefull
twin--turbo
Postby Shankie » Thu Nov 22, 2018 7:44 pm
twin--turbo wrote:Interestingly.... after replacing my 2 dodgyish batteries with to nice big new ones... I have done 20 miles without noticing any part load flutter.
Is it luck?
Is it cured????
That's interesting. Do report back!
Sent from my ONEPLUS A5000 using Tapatalk
2007 Mk7 Transit, 85 PS FWD
Shankie
Postby Ronald53 » Thu Nov 22, 2018 7:59 pm
twin--turbo wrote:Is it because the PCM was cleared of drive cycle data??
Yep, see viewtopic.php?f=54&t=101335
I did a reset of the learned parameters using Forscan, via the OBDII connector. Had the same effect.
Greetz,
Ronald
Ronald53
Postby DAZZ » Fri Nov 23, 2018 11:16 am
Greetz,
Ronald
has the judder returned at all?
DAZZ
Postby Ronald53 » Fri Nov 23, 2018 11:54 am
Yes, after a while it did. About a year later. Did a new reset, which again solved the problem.
Grtz,
Ronald
Verstuurd vanaf mijn SM-A320FL met Tapatalk
Ronald53
Postby DAZZ » Fri Nov 23, 2018 1:55 pm
Ronald53 wrote:Yes, after a while it did. About a year later. Did a new reset, which again solved the problem.
Grtz,
Ronald
Well Ive got a single battery van, so think she can have a night disconnected and see
DAZZ
Postby Steve192 » Fri Nov 23, 2018 9:52 pm
My 2.2 Euro 5 does the same thing.
How long do you need to keep the battery disconnected for to reset drive cycles?
Steve192
Postby twin--turbo » Sat Nov 24, 2018 3:43 pm
TBH I would not have expected a modern vehicle to lose the data from a battery disconnect, but I guess anything is worth a try.
I was changing to a Leather wheel at the time which was a ball ache, it was left 20 mins disconnected before I even started. The total down time was probably an hour.
twin--turbo
Postby DAZZ » Mon Nov 26, 2018 10:58 am
tried it.... guess what.... didn't make a difference :roll:
disconnected battery, earthed the positive lead as per previous attachment for an hour, had to reset radio etc, so assumed it was long enough.
DAZZ
Postby Shankie » Mon Nov 26, 2018 11:07 am
I *think* that this might have worked for me. It's not completely sorted, but it seems to have helped.
Shankie
Postby DAZZ » Mon Nov 26, 2018 12:27 pm
might have found a cure.... looked at a vito sport x at weekend :lol: :lol: :lol:
DAZZ
Users browsing this forum: Google Adsense [Bot], therightangle
