Hi, I'm a new possessor of a MK7 Transit VAN.
I've bought it for few money, because this van has been crashed, but not too heavily. It has some problem on central lock and ABS.
Central lock has been solved, but ABS not yet .
On the dashboard the ABS light is off, but the ESP light is on (i think it's the ESP, it's the same symbol as traction control off key)
The error on ABS module are
C0063:08-2B (wiring problem)
and
C0063:4A-2B (incorrect module installed)
I've checked the connection between yaw sensor (near steering column) and ABS pump ad they are ok.
Reading the value from oscilloscope tab of Forscan, it seems working (if I move the yaw sensor, it display an "analogue" waveform), so i really don't know why the error persist (it doesn't reset on DTC tab).
The only thing I've read is that yaw sensor could need to be re-calibrated. I've the suspect that the ABS pump has been replaced, and it need to be re-programmed.
What I need? I've only a ELM327 modified interface, is it enough or i need a VCM? Wich software should I use?
P.S. another error is the P251a:00-2F, PTO Enable Switch Circuit. what is it?
P.P.S sorry for my English
Thanks in advance for your reply and happy 2018:)
