loot wrote:Did you try reading the codes with the handbrake off? (Need to clear them first)
loot wrote:Yes it is known that on an earlier software it would cause brake fluid low switch fault dtc come up, but it was a glitch and if you clear the codes with the handbrake lever off(safely) then you get no codes again.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], SidTSloth
