SPARE WHEEL
SPARE WHEEL
Postby m20 » Mon Aug 06, 2007 9:45 pm
hi
sorry for yet another post about the spare wheel but i have trawled all the advice given so far (and the manual) all to no avail...
i have a mk6 transit which came with the spare in the back...
couple of hours on my hand and so i thought might as well put it in the right place...
removed the locking bolt, winched down the bracket with the wingnut...
can understand that this is put through the center of the wheel from above, hooked around and then wing nut back on and winced up again...
however, there is a loop of metal on this bracket with a steel cable attached...
whats that all about ?
totally confused...
regards
david
m20
Postby sc_BK » Mon Aug 06, 2007 9:58 pm
I think the cable goes through the centre of the wheel, but no really sure TBH
IMO best place for the spare is in the back :wink:
sc_BK
Postby Dan T » Mon Aug 06, 2007 10:08 pm
the bracket goes through the center of the wheel and a small stud will locate into one stud hole to prevent it spinning and allow it to sit on the wheel correctly. Then just winch it up.
Easy :!:
Dan T
Postby m20 » Mon Aug 06, 2007 10:10 pm
thanks - but what about the cable fitted to the hoop ?!?!?!?
m20
Postby easymove recovery » Mon Aug 06, 2007 10:36 pm
the hoop goes through the middle of the wheel and fixes up with the 2 wing nuts
EASY MOVE RECOVERY
VEHICLE TRANSPORTATION & 24 HR RECOVERY
NOTTINGHAMSHIRE BASED
easymove recovery
Postby transitgeoff » Mon Aug 06, 2007 10:43 pm
the bond is incase the winch cable breaks :D
transitgeoff
Postby m20 » Mon Aug 06, 2007 11:17 pm
what a bloody palava !
who though of that one ?
m20
Postby transitgeoff » Mon Aug 06, 2007 11:20 pm
well the mk5 didnt have it and when the cable rots and snaps the wheel just falls off, not good when your behind the said van :D
transitgeoff
Postby Nathan_Cardiff » Tue Aug 07, 2007 1:49 pm
Leave it int he back, its much easier to swap then if its p*ssing down with rain and you have to change it.
52 SWB Transit
Nathan_Cardiff
Postby Guy88 » Tue Aug 07, 2007 6:12 pm
transitgeoff wrote:well the mk5 didnt have it and when the cable rots and snaps the wheel just falls off, not good when your behind the said van :D
you got to have a spare wheel to use it thou geoff :lol:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
