MK7 FWD - Weird steering column squeak - any ideas?
Postby RacinRob » Fri Aug 17, 2018 11:04 am
My MK 7 FWD has developed a squeak from the upper steering column - it appears right below the steering wheel.
When cold/first thing, its as quiet as but within 5 miles, every time you turn the steering wheel it's there.
I removed the shrouds etc but no luck - its still there.
Also replaced the belt etc and all appears fine.
Just before I start stripping the column, I'm asking if anyone has found the same problem before.
Just thinking its a weird one because it only does it when the van warms up.
Cheers
RacinRob
Re: MK7 FWD - Weird steering column squeak - any ideas?
Postby knobby1 » Fri Aug 17, 2018 11:08 am
Upper steering column bearing dry..??
Postby andz327 » Fri Aug 17, 2018 2:02 pm
knobby1 wrote:Upper steering column bearing dry..??
Little bit of loose juice on on bearing lord knobster was talking but
Could be a Dodgy squib
andz327
Postby pippin » Sun Aug 26, 2018 4:50 pm
Mine does it too and it is getting worse - and harder to steer as well.
andz327 mentioned "Could be a Dodgy squib" - whatever that might be.
I have tried squirting IPA cleaner followed by PTFE lube without effect.
What I can't figure out is how to get at the top of the bearing to get it into the right spot.
Somewhat frightened about disturbing the airbaaaaaaaaaaaaaghhhhhh!
My garage reckons the cure is to replace the steering column - but I'm not made of money.
Thoughts?
Ta
pippin
Postby pippin » Mon Sep 03, 2018 11:21 pm
Bump or rather squeak!
Anybody?
pippin
Postby pippin » Wed Oct 17, 2018 9:07 pm
Update:
I got a s/h steering column and my garage fitted it.
They were quite honest about not being sure that was the problem.
Indeed, the original column was just as free to rotate as the replacement.
It ran OK for a fortnight but now the squeak has returned. :evil: :twisted:
Any more thoughts guys?
pippin
Postby knobby1 » Thu Oct 18, 2018 12:25 am
Uni joints between the column and rack..?? Dry ball joints..??
Give em a spritz with WD40, free to try.
Postby andz327 » Thu Oct 18, 2018 1:15 am
knobby1 wrote:Uni joints between the column and rack..?? Dry ball joints..??
Squeaky squib/clock spring
Is squeak inside or ootside
Sent from my LG-H870 using Tapatalk
andz327
Postby pippin » Fri Oct 19, 2018 5:31 pm
Squeak is inside, for all the world as though it is coming from the squib area - but it ain't that.
Will have a go at the other suggestions.
Thanks guys
pippin
