Hello
How I can remove speed limitter (90km/h(56mph)) on my transit 2.4 TDCI -05 mk6?
Fuse? forscan?
blue estate wrote:What gvw is it if a 430 , you can't
Altransit wrote:Is it a Minibus
I can't understand why a van has a 56mph limiter if it's not over 3500kg
geeteevee wrote:Car: Transit 2005 2.4 tdci 350L VAN-3.55T
Speed limitter: 90km/h (56mph) because finland
Tachograph: Stoneridge 2416 fxp
Ford dealer is not solution. Car inspection is every year and I have to turn on the limiter every year
dumper wrote:Yes a bit different for vans my 460 twin wheel bus could only have taco and speed limiter removed by Ford dealer when I got the logbook back as a motorhome if the op van is a 350 the speed limit may have been put on by the original owner the local council vans near me are limited to 56 even the customs .
Before I had the limiter removed it was limited to 62 mph on the taco but read 67 mph on the speedo but as op is in Finland it’s different I thought it was the same all over Europe
