Hi All
I'm trying to replace the battery in my mk7. Have looked at the owners manual which is NO help!! How do you remove that plastic cover above the battery? Cheers
karl wrote:i remove the seat
Altransit wrote::idea: You could always remove the four 13mm AF nuts holding the seat to the base, and then just tip the seat over onto the passenger seat.
ake wrote:Altransit wrote::idea: You could always remove the four 13mm AF nuts holding the seat to the base, and then just tip the seat over onto the passenger seat.
That’s how I’ve always done it, no need for torq bits, just a 13 mm spanner
