dumper wrote:Not really looked at mk7 but is there a panel in the bumper to get to the hook or do thay have a screw in tow eye like mast new cars & this mk8 it’s even possible that all manufacturers use the same thread so one off another vehicle will fit
Yes it fits straight on same mountsBarra1956 wrote:After driving a MK6 85/280 Tourneo for 7 years I bought a MK7 85/300 now.
I would like to mount the towing hook from my 2006 MK6 to my 2010 MK7.
Will the towing hook fit to a MK7 ?
v8dave wrote:The bcm was not designed for the extra load of the trailer although with this being a commecial vehicle it probably should have been.
richgold wrote:v8dave wrote:The bcm was not designed for the extra load of the trailer although with this being a commecial vehicle it probably should have been.
FTFY.
I know yer supposed to get the extra bits but I'm on my 2nd mk7 and both have been wired to rear lights with no problems but mind you I've only done around 540.000miles like that so maybe its just luckv8dave wrote:richgold wrote:v8dave wrote:The bcm was not designed for the extra load of the trailer although with this being a commecial vehicle it probably should have been.
FTFY.
Ford designed a wiring addon for towing so that the bcm does not need to do the extra work.
The ford bypass relay unit lives in the cab behind the step liner on the side opposite the jack storage.
andz327 wrote: no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
Sent from my LG-H870 using Tapatalk
I know sir it's mad when i think about it hahaha and in between them was ma mk6 and i done over 200k miles in that, and before the Fords 340k miles in vw caddy, 250k miles in a Scudo and 40k miles in Ren traffic all in the space of 13yrsknobby1 wrote:andz327 wrote: no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
That's close to the moon and back mate..!!
andz327 wrote:I know sir it's mad when i think about it hahaha and in between them was ma mk6 and i done over 200k miles in that, and before the Fords 340k miles in vw caddy, 250k miles in a Scudo and 40k miles in Ren traffic all in the space of 13yrsknobby1 wrote:andz327 wrote: no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
knobby1 wrote:I know sir it's mad when i think about it hahaha and in between them was ma mk6 and i done over 200k miles in that, and before the Fords 340k miles in vw caddy, 250k miles in a Scudo and 40k miles in Ren traffic all in the space of 13yrsandz327 wrote:knobby1 wrote:[quote="andz327"] no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
