Towing hook
Towing hook
Postby Barra1956 » Tue Sep 04, 2018 7:19 am
After driving a MK6 85/280 Tourneo for 7 years I bought a MK7 85/300 now.
I would like to mount the towing hook from my 2006 MK6 to my 2010 MK7.
Will the towing hook fit to a MK7 ?
Coming together is a beginning; keeping together is progress; working together is success.
Barra1956
Re: Towing hook
Postby twin--turbo » Tue Sep 04, 2018 9:39 pm
essentially the same chassis so should do.
twin--turbo
Re: Towing hook
Postby dumper » Thu Sep 06, 2018 9:51 am
Not really looked at mk7 but is there a panel in the bumper to get to the hook or do thay have a screw in tow eye like mast new cars & this mk8 it’s even possible that all manufacturers use the same thread so one off another vehicle will fit
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Towing hook
Postby andz327 » Thu Sep 06, 2018 11:27 pm
dumper wrote:Not really looked at mk7 but is there a panel in the bumper to get to the hook or do thay have a screw in tow eye like mast new cars & this mk8 it’s even possible that all manufacturers use the same thread so one off another vehicle will fit
Barra1956 wrote:After driving a MK6 85/280 Tourneo for 7 years I bought a MK7 85/300 now.
Yes it fits straight on same mounts
andz327
Re: Towing hook
Postby v8dave » Fri Sep 07, 2018 12:54 am
If you mean the front towing eye then Mk6 is vertical loop with appropriate bumper cut out, Mk7 is horizontal and has a different bumper cut out.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: Towing hook
Postby twin--turbo » Fri Sep 07, 2018 8:49 am
I am assuming we are talking "Tow Bar"
twin--turbo
Re: Towing hook
Postby Barra1956 » Tue Sep 18, 2018 7:41 am
Sorry, YES, I meant a tow bar.
Are there(electronical) issues to take into account when installing a 7-point connector box or is it merely a matter of quick connectors ?
Barra1956
Re: Towing hook
Postby v8dave » Tue Sep 18, 2018 7:50 pm
If you mean the type of "quick" connector that is squeezed on to the wire and cuts the insulation then my personal opinion is that they are the work of the devil.
Mk7 needs a proper bypass relay unit and independent power feed to control the trailer lights.
The bcm was not designed for the extra load of the trailer.
v8dave
Re: Towing hook
Postby richgold » Tue Sep 18, 2018 8:41 pm
v8dave wrote:The bcm was not designed for the extra load of the trailer although with this being a commecial vehicle it probably should have been.
FTFY.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Re: Towing hook
Postby v8dave » Tue Sep 18, 2018 11:37 pm
FTFY.
Ford designed a wiring addon for towing so that the bcm does not need to do the extra work.
The ford bypass relay unit lives in the cab behind the step liner on the side opposite the jack storage.
v8dave
Re: Towing hook
Postby andz327 » Thu Sep 20, 2018 12:29 am
v8dave wrote:
FTFY.
I know yer supposed to get the extra bits but I'm on my 2nd mk7 and both have been wired to rear lights with no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
Sent from my LG-H870 using Tapatalk
andz327
Re: Towing hook
Postby knobby1 » Thu Sep 20, 2018 1:12 am
andz327 wrote: no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
That's close to the moon and back mate..!!
Re: Towing hook
Postby andz327 » Thu Sep 20, 2018 3:31 am
Just saying
I know sir it's mad when i think about it hahaha and in between them was ma mk6 and i done over 200k miles in that, and before the Fords 340k miles in vw caddy, 250k miles in a Scudo and 40k miles in Ren traffic all in the space of 13yrs
andz327
Re: Towing hook
Postby knobby1 » Thu Sep 20, 2018 3:44 am
andz327 wrote:
Just saying
Damn..!! That's a lot of miles.. :shock:
Re: Towing hook
Postby andz327 » Thu Sep 20, 2018 4:57 am
knobby1 wrote:
andz327 wrote:
knobby1 wrote:[quote="andz327"] no problems but mind you I've only done around 540.000miles like that so maybe its just luck
Just saying
Lord Knobrot[/quote]Yeah just a bit mate
andz327
