Replacing repeater on a jumbo
Postby imageoven » Thu Sep 06, 2018 4:13 pm
My nearside indicator repeater light is hanging off, snapped mounts that appear to be screwed from inside the wing. Its the one mounted to the metal of the wing rather than the little one under the mirror that some have. Do I need to take off the wing to replace it or do I take off the ecu...
Mine has been silicone sealed around the edge but not sure if that's just someone's previous repair?
Edit; 2007 Mk7 ELWB RWD 350 100PS
imageoven
Re: Replacing repeater on a jumbo
Postby karl » Fri Sep 07, 2018 9:10 pm
take the plastic inner wing out and you can just about get to 2 ten mm bolts :D
done one the other day on a mrk 6 :D
//www.ebay.co.uk/itm/FORD-TRANSIT-MK6-MK7-FRONT-LEFT-PASSENGER-SIDE-INDICATOR-REPEATER-LIGHT-LAMP/273030832276?hash=item3f91e7e094:g:55MAAOSwIBJaYLFW
karl
Tranny Lover!!!
Postby imageoven » Fri Sep 07, 2018 10:26 pm
Thanks Karl.
Where is the 'inner wing' I had a peer up from underneath in the wheel arch - I thought it was all solid steel and I didn't see anything to remove, or should I be looking into the engine bay...I just see the ECU in the way and then another steel inner panel - I'll have to go back and look again. google isn't helping me here.
imageoven
Postby ned » Fri Sep 07, 2018 10:34 pm
See that black plastic bit
Remove that and you should be able to reach up
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby karl » Fri Sep 07, 2018 10:37 pm
imageoven wrote:Thanks Karl.
pop ya head back in and above the light "inside the wing "their is a cover to the front of the van . i call it the sh*t catcher :lol:
karl
Tranny Lover!!!
Postby imageoven » Fri Sep 07, 2018 10:41 pm
Ah perfect thanks Chaps.
Very good of you to take the wing off for me Ned, makes it very clear :)
imageoven
cron
