Hello, is there a solid flywheel conversion available for a 2012 mk7 Euro 5 2.2 fwd?
Could someone post a link if possible?
Cheers
Try on ebay TPUK will probably have what uou need, i put solid on my mk7 130 e4 and just used fly wheel and clutch from a 110ps same 5sp gearbox which was actually same as an 85ps from Euro carparts and was proper LUKSteve192 wrote:Hello, is there a solid flywheel conversion available for a 2012 mk7 Euro 5 2.2 fwd?
Cheers
karl wrote:All ford engines from 2001 right upto 2016 use the same crank, so they all must use the same flywheel
bambi mk 1 wrote:karl wrote:All ford engines from 2001 right upto 2016 use the same crank, so they all must use the same flywheel
How many crank locking pins are there in your timing pin kit Karl
karl wrote:bambi mk 1 wrote:karl wrote:All ford engines from 2001 right upto 2016 use the same crank, so they all must use the same flywheel
i have them all
one for the mrk 6
one for the mrk 7/8 2,2
mmmmmmmmmmmmmm dont have one for the mrk 8 euro 6 2.0 thow
