davyjcb wrote:On the top of the front drv side strut turret behind the dash you will find the main loom above and to the r/ hand side of the accelerator pedal there will be a single wire ,blue with a green trace in the loom terminated in a 1/4 female spade terminal this is an ignition live IT ONLY CARRIES 1 AMP this can be used to drive a relay
Get a 4 pin relay and wire it as follows pin 85 connects to the blue green wire pin 86 goes to a good ground cut the live wire of your accessory plug and the live side goes to pin 30 pin 87 then rejoins the the accessory plug
You can put a fuse inline if you want but as its already got one it's not required
