Airthies wrote:What I have noticed is there's no ballast weight in the engine crossmember on the 3.2
Sent from my anu5 using crapatalk
6no it'll be pretty much the same on 3244 I'm not going to start redesigning just yet, will see how it goes for a while, if I lift it much more I run into other issues I need to deal with like steering pipes and longer brake lines etc. So for now it's going to be a straight swap when it's ready.Punto443 wrote:Woohoo
Are you going to mod the front diff position on the new one?
I remember you pointing out it still sat at slight angle.
Yes please and one of those flashy switches too if possiblePunto443 wrote:Oh yeah, do y’all want a big yelly handle for when you open the side door?
If I find the other ring ill get a vid of it while it's getting it's hole oppened, more rimmed, than smashed in thoughloot wrote:I'm not sure what I'm seeing but it looks very impressive
loot wrote:Ah i thought as much, are you allowing for expansion? (pretends to know what he's talking about)
Nah it's massively simple stuff, nice to have it there too crack on with.
I might buy a lathe
