Airthies wrote:No it's just further into the nose conened wrote:Can you not swap the sprockets from one starter to the other? One looks smaller on the picture.
Ah that's a bugger innit, I wonder if you could pull a starter from the junk yard with a smaller sprocket, cog whatever its called and swap it into the new starter, that said if you make an adapter plate and it works then at least you can easily fit a new starter if tours ever fails, just thinking out loud
